Discuss Precast concrete garage in the UK Electrical Forum area at ElectriciansForums.net
robd
Hi all,
A bit off topic but I am looking at getting a precast concrete garage at mine and wondered if anyone else had one or any thoughts on them?
Was going to brick build one but think it's too expensive for what I need it for.
Thanks in advance
My Dad doesn't have a garage but he did get a pre-cast concrete shed.
Seems alright. I guess it depends on the make but having worked on one and having listened to my Dad complain about it, fixing stuff to the walls can be a bit of a pain as they can be quite thin in the middle of the sections making securing say back boxes a bit problematic unless you stick them on a bit of timber screwed to the thick edges where the panels join.
Depends what you're going to put in there aside from a car I guess. Dad had a few problems with roof mountings leaking which wasn't good as he has a lathe and other bits of machine shop gear in there.
Interesting thanks. I don't want it for a vehicle either and I've spoken to other people and roofs seems to be one downside.
Want mine for similar things as your dad by the sound of it, a bit of storage and a workbench. Had wondered about fixings for a few sockets, thought it would have to be a baton or whatever.
Thing is a garage will cost me a few thousand more if I brick build it and it's just for my work stuff so can't justify it.
Thanks I will call them they look a nice quality did you pick yours out of the catalogue or were you able to go and have a look?
Thanks yes had thought of the duct. Have requested a brochure I'll call them, Rotherham is a bit of a drive from Suffolk to go and have a look though :confused:
Just don't leave anything like tools inside, they get very damp. Ours has no insulation whatsoever which means when it's warmer outside the damp air comes in and cools down, and vice versa. Left my tools there one winter due to building work and they were all covered in rust.
Now i don't keep anything more than offcuts of wood and old bricks/sand in there.
With a bit of heat or dehumidifier in the it would be ok.
The other thing is take care with the base, don't make it too big otherwise the water can get under the sides. And include a dpm in the floor.
they work all over the country and fix it on the first day .all you need is for some one to do the base .
Thanks yes just meant for going to have a look. It's not be all and end all, from looking at websites etc they definitely look a better quality than some of the others
Thanks John very helpful want it to store a bit of gear etc, general work store with workbench and maybe the lawn mower etc. Maybe it would pay to insulate a bit? Could out a frost watch heater in there for sure
Not really Rob, just a proper heavy duty shed done in 3 x 2 tanalised timber. There are usually specialist shed companies around who will quote and build to your requirements as well as supply the more 'standard' sizes.
Timber is a nice idea but you have to worry about premature deterioration of the building itself if it's not detailed properly. With concrete it will spall eventually and the rebar rust, but it will deal with being wet very well. Also it's more secure if that's a concern (notwithstanding the door and roof)
Reply to Precast concrete garage in the UK Electrical Forum area at ElectriciansForums.net
Was having a poke around the old man's house today. Anyway. DB is under stairs (18th ed following a recent extension. Not done by me but it's...
Hi guys, Can I ask you a DIY question? I'm refurbing a detached garage and adding a garden building. Garage currently has a submain supplied by...
Hi all, Would like some advice on the below. Context: Rural French domestic installation TT system Earth rod is situated inside the property...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
Hi there, long time lurker, first time poster here. Straight down to it.. A friend asked me to add some sockets and additional lights to a small...
