Discuss Prefect pre2975 switch ? in the The Welcome Forum area at ElectriciansForums.net
dizzle94
Hi we have been working on a student accommodation site . And have been installing PREFECT PRE9275 hob timer switch in a small copact kitchen. These have been getting installed only half an arms length away from the sink on the splash back. I am just wondering what is the minimum distance from a sink should the button switch be placed.
P's would post a picture but don't know how :cheesy
BS 7671 does not specify any minimum distance for socket-outlets to be from a sink. However, regulation 512.2.1 requires external influences to be considered when selecting equipment for a particular location. Accessories used in domestic installations are not designed to be splashed and therefore not suitable for installation close to a sink or draining board. For this reason, it is recommended that socket-outlets and other accessories should be located at least 300 mm, measured horizontally, from a sink or draining board, where they are less likely to get splashed.
The above is quoted by the ECA ^
Just reading ITE Electrician's Guide to The Build Regulations
Page 60
5.2.2 Location of accessories in kitchens
IV) Accessories should be installed a minimum of 300mm from the edge of kitchen sinks and draining oards to reduce the risk of being splashed.
Reply to Prefect pre2975 switch ? in the The Welcome Forum area at ElectriciansForums.net
