Discuss Pressure relief valve and pressure relief device in the Australia area at ElectriciansForums.net
Thought a pressure relief was a bursting disk which vented rapid gas build up due to a fault, whereas a Buckholze Relay (check spelling!!) was used to shut the transformer down when a fault condition occured within the transformer due to the rising pressure generated.
It was a long time ago when I did this :)
Reply to Pressure relief valve and pressure relief device in the Australia area at ElectriciansForums.net
  • Locked
Hi, I realise this is an electrical forum and not plumbing, but was wondering if somebody could help. My heating is not working and the heating...
4K
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
For the past few years, I have used a hydronic system (outdoor wood boiler) with both high and low temp working simultaneously. The low temp...
Anyone know what kind of device this is and brand name used? Its connected to a pressure switch.
wiring a 480 volt 3 phase 114 amp generator to run 2 machines. Both machine nameplate 480 v 3 phase 50 FLA. What size wire and over current...
