Discuss problem of circuit protection in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
H
hamanor
Hello, after shutdown of power supply ,at the next time of start, my water pump it is breakdown. I think my circuit protection is not approperiate, because it is the second breakdown !!
please,how to protect my installation correctly.
thank you
Try a DOL starter with correctly sized overload.
Is this water pump for a pressurized water supply system to your house??
If so, your pump should incorporate a thermal overload device as well as an over pressure cut out, normally all mounted on the pump motor casing. Maybe all you need to do is reset the overload/reset button. Sometimes, depending if the pump was running at the time of a power cut, or when power is restored, can cause a current spike that will trip the the integral motor protection.
Get a local electrician to check your motor and it's controls out, if this is an ongoing problem for you!!
Reply to problem of circuit protection in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi guys, could someone help with the following please? The scenario is: Domestic property supplied via three phase (with a 3P main DB, NO SPD)...
I recently got my flat rewired. It had old storage heaters and we plan on putting modern storage heaters in. The way the electrician did the...
I have Curry's Essential tabletop dishwasher model CDWTT115 for nearly five years. Earlier this year my machine have stopped running during a wash...
If someone made a request to you, to install a new double socket that would be supplying power to a tumble dryer along a circuit that does not go...
Hello Need to replace a distribution board in the next few weeks to allow for more circuits to be installed in January. Existing is a TT system...
