Discuss Problem on job with bungalow in the Electrical Forum area at ElectriciansForums.net
A
axel132132
Hi
I have an issue at a bungalow im working at, there is a fault
All the sockets are on a ring, when i plug something in the living room it trips the RCD plug it into any other sockets it dosent trip the RCD
The board is MAIN SWITCH RCD
Cheers
check the living room sockets. suspect a N/E reversal.
Hi
Cheers
Please answer the bit in Red how have you established this ?
J
used to be a good code 3 on the old PIRs..... further investigation required.
Still think its faulty skt if no tripping anywhere else.
will only take 2 mins to prove / disprove
Yeh will change socket and megger old socket at back to check if its shorted anywere thanks for help hopefully its socket and will save me some time :24:
is it only 1 socket that it trips on, or all the sockets in the room?
New posts
Reply to Problem on job with bungalow in the Electrical Forum area at ElectriciansForums.net
