Discuss Problem on job with bungalow in the UK Electrical Forum area at ElectriciansForums.net
A
axel132132
Hi
I have an issue at a bungalow im working at, there is a fault
All the sockets are on a ring, when i plug something in the living room it trips the RCD plug it into any other sockets it dosent trip the RCD
The board is MAIN SWITCH RCD
Cheers
Hi
Cheers
Please answer the bit in Red how have you established this ?
J
used to be a good code 3 on the old PIRs..... further investigation required.
Yeh will change socket and megger old socket at back to check if its shorted anywere thanks for help hopefully its socket and will save me some time :24:
is it only 1 socket that it trips on, or all the sockets in the room?
New posts
Reply to Problem on job with bungalow in the UK Electrical Forum area at ElectriciansForums.net
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hi, I swapped a 2 gang switched socket for a 2 gang switchless socket with usb ports downstairs. I switched off all the power to the house by...
Hi Guys, I'm having trouble diagnosing a fault on a customers downstairs socket ring, which only ever trips when the washing machine is used. The...
