Discuss Problem with a shower in the UK Electrical Forum area at ElectriciansForums.net
A
Afrohan
Trying to answer a question with regards a fault on an electrical shower.
The question reads: A fault has occurred on an electric shower , when the shower was turned on a crackling sound was heard coming from the shower, the lights in the room then flickered and dimmed before the shower fails and turns off.
What are the likely faults that can produce these symptoms?
I thought that it may be a loose termination causing an open circuit or even a short to earth and the surge due to either of these eventualities would temporarily cause the lowering of voltage to flow through other circuits.
Any thoughts on the subject would be gratefully appreciated cheers!
There is limited information in the question. However a crackling sound is indicative of a loose connection arcing as contact is made and lost.
The creation of a sustained arc for a short time could cause a high current to flow in the circuit which would have the effect of dropping the supply voltage to the property and causing the lights to dim.
Since the arc is taking a high current the protective device would then operate and cause the shower to stop. Alternatively the arc can have burnt out the terminal / cable so that the temporary contact can no longer be made.
Reply to Problem with a shower in the UK Electrical Forum area at ElectriciansForums.net
I am not an electrician but am looking for some advice as to how to fix my sporadic light flickering problem that has come and gone for the year...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Hi everyone, I need some help with an electrical issue I'm experiencing. I recently created a new circuit for an electric oven at my friend's...
Summary (TL;DR) Several lightbulbs in my home supplied by one circuit breaker dim over time and go out in about a year. Right now, the ceiling...
I have the typical LED on Dimmer switch. All the lights flicker in my house are very inconsistent times. By let me clarify by saying all the...
