uHeat Banner - Forum Discount Available
Advertisement - Content continues below
Discuss Problem with mains outside light, any help please? in the Electrical Forum area at ElectriciansForums.net
M
MadeUpName
Hello!
I've put up a mains outside light,
Been working fine for about 2 weeks,
Now it's not working!
When I turn it on and off at the mains, the bulb flashes once like a camera, and doesn't light up.
I've checked all wiring connections in the light and the plug,
Everything is connected.
Left it unplugged for 10 minutes, to reset the light, that doesn't work,
I've replaced the bulb, even turned it round, and made sure the bulb is fitted properly.
I have no idea why it's stopped working?
Any advice please?
Thank you!
SuperlecDirect - ElectriciansForums.net Electrical Suppliers
Wilko
Hi MUN and welcome to the Forum :)
Any chance of a pic of your light?
I'm thinking water may've got in it. IP rating?
Deleted member 9648
  • #4
Probably a rubbish light and the sensors packed up, don't be so tight and pay for a decent one.
Strima
If it's LED the driver has probably packed in.
littlespark
Advent Win
From what I understand, this is just a light, no sensor and a replaceable bulb. Powered from a cable with a plug on it, plugged into a standard 13A socket.
If all connections are tight, and bulb works in another fitting (try that, to rule out the bulb) then the problem could be the socket. Try it in a known working socket, using an extension lead if you have to.
You have to eliminate any possibilities to narrow down where the fault could be.
T
The Ghost
  • #7
You could push the boat out and and try a new bulb.
Deleted member 9648
  • #9
Why would the OP leave it unplugged for 10 minutes to 'reset' a bulb?
Can be understood as a part of abnormal aging or short circuit, after the overheating of the circuit of a self-protection on the open, so black out, black out, because there is no current, the temperature is back to normal, and bright.
I'm a professional electrician. I've seen this a lot. Can consider from the following aspects: 1. If both ends of the tube black, the general is broken, it is suggested that the yellow pavilion lamp. 2. If both ends of the tube are on and the starter keeps on for a long time, replace the starter. 3. If the temperature is low, it will be more difficult to start the fluorescent lamp。
M
MadeUpName
  • #14
Thanks you guys!
Love the humour!
Fixed it!
Bye bye forever!!!
Reply to Problem with mains outside light, any help please? in the Electrical Forum area at ElectriciansForums.net
Aico Carbon Monoxide Detectors
Top Bottom
