Discuss Problems fitting Fused Timer Spur Switch in the DIY Electrical Advice area at ElectriciansForums.net
I purchased a 7 day timer fused spur switch to replace a standard fused spur on a downstairs wc electric towel radiator. It seemed like it would be a simply swap out. However, it looks like the water supply earth bonding is connected into here and uses a thicker earth cable than the new spur switch can cater for, as the existing fused spur connections are inadequate. I have included images showing the existing spur switch and new timer switch and connections. Any suggestions on how I can resolve this? Choc blocks were originally there but the wago clips are simply there to protect the connections whilst I ponder a fix. Thanks for your help.
TL;DR
Replacing fused spur with timer version, but earth bonding in original spur! Help!
You can put the 3 earth connections, plus one for the timer, into a 5-way level Wago connector. Possibly the smaller 221-415 type. Assuming the back box is big enough (or change it for a deeper one, if needed).
I did also wonder if this timer is a Class II device with an earth terminal for convenient only i.e. not actually needed, you could also check the instructions that came with it to see if that is the case. But in any case, the other 3 earths do need connecting together.
Thanks for your reply. I will give this a try.
Reactions: DPG
Reply to Problems fitting Fused Timer Spur Switch in the DIY Electrical Advice area at ElectriciansForums.net
Hi I have a switched fuse spur where the cooker hood should plug in to… above the actual cooker. I was wondering if I could swap this out for a...
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
Wiring cooker hood into a switched fuse spur with a 13amp fuse in the spur. The cooker hood is 3amp. Should I swap out the 13amp fuse in the spur...
Hi, I have ran a light ring off a fused spur with two lights on, each with their own switch (outside and lobby light) I want to put the outside...
