Discuss Protect Fused Spur? in the UK Electrical Forum area at ElectriciansForums.net
Thanks AshrowI would say no
I personally would of not had the switched fused spur behind the chimney as if the fuse goes you have to take the chimney apart to get to it.
But you don’t think the heat will be an issue?I would say no
Thanks JamesMost sockets and spurs are made from thermosetting plastic that will not melt when exposed to the sort of heat you are likely to get there.
Realistically if it is getting too hot in that area the first thing likely to fail will be the fuse if it is loaded anywhere near it’s capacity.
i wouldn't worry. the level of heat there will not be enough for a mouse's breeding nest. let alone damage a FCU.Thanks James
It’s a 3 amp fuse so guess it wouldn’t take much? If it’s an issue I wondered if I could put something between the duct and spur, like a heat resistant pad or something?
Lol. Many thanks Telectrix ?i wouldn't worry. the level of heat there will not be enough for a mouse's breeding nest. let alone damage a FCU.
Reply to Protect Fused Spur? in the UK Electrical Forum area at ElectriciansForums.net
