Discuss Protection to be used on a 5KW motor??? in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm Dave and I was wandering if I could have help with something.
If I were to wire a 5KW motor what means of protection should be incorporated into the inverter for compliance with BS 7671?
Thanks! :)
What does your risk assessment state, as this will have a big factor in your question?
On a good note, while we wait for the OP to come back to us and answer our questions, I now have the 2018 version of 60204.. :smile::smile::smile:
Welcome to the forum Dave, we would need a lot more info' than provided by you question.
If you are enquiring on overload protection of the motor then the VSD will provide that if set up correctly.
If you are discussing electrical noise like harmonics then refer to the manufacturers instructions for the drive, many drives have inbuilt or footprint filters already on them for the smaller sizes.
If you are asking about upstream fusing for the drive then again refer to the manufacturers instructions for correct sizing.
If you are looking into using external supply control voltages and commoning 0volts to the drives 0volts then that depends on the way the control power supply is arranged.
This really isn't covered by the BS7671 which focuses more on the power supply to the machine/control unit, this falls more under the machine code regulations.
Reply to Protection to be used on a 5KW motor??? in the UK Electrical Forum area at ElectriciansForums.net
Hi folks, I have recently had a 5kW Solis inverter and 15kW/hr of batteries installed. Everything is working fine, but I have some concerns about...
Friend of mines dryer machine has stopped working, 2 days out of warranty. I am trying to help theme out as money is tight for them however, I'm...
I disassembled a Christmas light projector to try and identify the cause of why the images from the projector weren't moving at all, when they...
I used 12v dc from a 13 plate car battery to power a 12v dianamo dc motor and brought in an alternator to change the battery using the rotation of...
I have seen recent changes that require (most) EV chargers and solar systems to be fitted with a type B RCCD. I work with power semiconductors...
