Discuss Proteus rcbo Went bang in the UK Electrical Forum area at ElectriciansForums.net
why did it go bang over loaded!Existing proteus rcbo went bang,any one had a similar problem,I haven’t switched back on yet.
The DB about 10 years old,don’t need this hassle.
nothing goes bang without a reason !No reason ,just went bang, replacing with another tomorrow
What he said Proteus, load of carp imo CEF's own make I believe, I had to do a job in Berlin, and got the said wholesaler to make me up a bespoke 2 consumers unit set up in a IP rated enclosure, ( no time allowed on site to do it myself) it came, it got installed, it got tested and it went Bristol's up after about 2 hours, no load just went that's it I aint working no more, Pete999 was not a happy Bunnie call the salesman that provided it, that he could stick his custom up a dark hole if that was the sort of service he was giving me. Went to an Independent outfit got great service good prices, and the the provided a replacement NOT Proteus I hasten to add, terrible stuff.Proteus.......there’s your problem. Upgrade to better quality.
Never got that far with my set up.I’ve had an rcbo (QOE Square D) go bang once, but that happened when pressed the test button.....ended up with a blackened finger!
Was going to say that bus bar looks iffySee the clean 6A MCB in this photo - I fitted this a few weeks back...
the previous one gave up the will to live - as you can probably tell, the CU had suffered some water ingress .............. from the old leaking bath above which has now been all replaced
A nice shiny new CU has just been fitted!
Agree I was a weapons technician in the forces and nothing goes bang without a cause and trigger!nothing goes bang without a reason !
??????other one test button failure.
Reply to Proteus rcbo Went bang in the UK Electrical Forum area at ElectriciansForums.net
