Discuss Proven Wind Turbine in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Does anyone know anything about these wind turbines. I have one which is off grid and would like to attach it to a on grid inverter, would there be an issue in doing this
It depends which model of Proven it is. Some of the old off-grid models were only 48V so it will be difficult to find a matching grid-tie inverter. The 2.5kW and 6kW grid-tie versions generate a fluctuating 200-600V wild 3-phase AC (varying with blade rpm) so need a rectifier before feeding DC to a grid-tie inverter.
I have the 6kW grid-tie version.
You will need to find out what its output voltage level is. Is it charging batteries or connected to an electric heating system?
It is possible to have the generator core changed to a grid tie (nom 300V wild AC) version. As above, then rectifier, then Windy Boy inverter to grid tie. Certainly worth speaking to Kingspan Wind about this to see if they will carry this out on a Proven machine.
Reply to Proven Wind Turbine in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello everyone, I'm currently working on a project to upgrade an existing renewable energy system and could really use some expert advice. The...
I have an old sunnyboy 1700 and I'm trying to connect it to a 1kw wind turbine. I've been told that if I can get into the inverter software to...
And now for something completely different! I have been after a power station telegraph for decades and due to the fact most would have been...
I am a Napit registered electrician and want to get into Solar PV and battery storage. I have boot camp booked in April but am not hearing good...
I'm just wondering if anyone knows whether any/all of the Quinetic grid switch modules fit in a 25mm back box? It "looks" just about ok. But if...
