Discuss Providing a local earth to distant circuit in the UK Electrical Forum area at ElectriciansForums.net
Hi and thanks for reading and any helpful response.
I need to wire up an 11kw sauna heater about 60m from the main fuse board in the house. I thought I could run live and neutral in 16 mm in 25mm conduit the 16mm allowing for voltage drop over such a long run. My main question is could I put in an earth stake near the sauna thereby savin
Singles on pvc conduit underground sounds a bit ropey. Can you not use SWA?
Reply to Providing a local earth to distant circuit in the UK Electrical Forum area at ElectriciansForums.net
Can someone sanity check my thinking please.... An 80 amp PME service head, tails to meter, 25 sq mm tails into an enclosed fused isolator with...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
Over the last few days, I have stumbled across a number of threads that seem to point to a prevalent misunderstanding. Either that, or I have been...
I'm new to this but stuck with an issue, so I'm looking for some help wherever possible. I have just completed a rewire, which I have a potential...
