- Reaction score
- 3
Hi
I'm Rewiring a pub/resturant complex and the owner would like to have dimmable led lighting thoughout inside
it'll be a mixture of the jcc led 7's tiltable and tracklighting with pendants with either an 8w or 11w dimmable led bulb in hovering over the tables
the'll be around 140 lights in total and all lights will be switched from behind the bar
there will also be ground uplights outside, i have pulled out a 1.5mm 2 core armoured to supply some walk over uplights leading up to the entrance ( about a 25m run) how many can i safely put on this if i use an led uplight on a 6 or 10 amp rcbo?
there will be car park lights and driveway lights, i have run a 2.5mm armoured for these, how many can i safely put on without tripping an rcbo, the first light is a run of 30m aromoured, if i were to carry on all the way to the entrance it would be an 80m run to the last light
how many should i allow on each dimmer, i'm presuming about 6-8?
should i go for one bank of 24 grid dimmers or should i go for 6 banks of 4?
many thanks, sorry about my inexperiance with led lighting, whenever i've installed in a domestic install i've stuck to 10 jcc led on a circuit max
