Discuss Pull cord call system testing cost in the Commercial Electrical Advice area at ElectriciansForums.net
T
Tiberius
Hi guys, been asked to give a quote on testing pull cord facilities in retirement homes but have no idea what the Base rate roughly is for doing this?
Each bungalow has a small main unit (tynetec), bathroom pull cord, smoke alarm attached and the wireless pendant for residents.
If anyone can give me an idea on the rates for testing thelse I would appreciate it.
i'd charge a normal call-out fee ( £40 ish ) to cover up to 30mins on site, then hourly rate at 30 min increments if more time required. obviously if you are doing several homes in the same area, this can be discounted. also dependent on what paperwork/certificates are requested by client.
Reply to Pull cord call system testing cost in the Commercial Electrical Advice area at ElectriciansForums.net
Hi all Recently we've been having a few issues with smoke and heat detectors.. been fitting them for years and years now mostly without any...
Not come across this before, so would like some help, please. I went to install smokes and heat alarm (to new Scottish regs) in a fairly modern...
Having a bit of a mare at the moment with a small 2 story HMO (6 single rooms with shared kitchen) which was fitted relatively recently (2016 or...
Doing one more of the flood of EICR today on a rented property before a tenant change, but ran into a slightly interesting case so would...
12K
Is there a room in professional PAT testing for a business model other than 'per unit'? I ask because I've been giving this some thought. I've...
9K
