Discuss pulling my fuse out nightmare in the UK Electrical Forum area at ElectriciansForums.net
s.keech
hi just contacted d.n.o about fitting isolator for a c.u. change for elecsa assessment in my own flat. They said get a registered spark to do the work. then I replied that I need isolator so I can do the work and register. They then said to register with elecsa and then do work. I cant register until I complete the work and can not do the work unless it is isolated. Am I just getting dizzy going round in circles or just pull fuse and do work. I have 2330 level 3 so classed as competent but are they? what do I do?
It looks to me as though you have made "best endeavors" to do things through the proper channels and have got nowhere.
If this was me, I would do a Risk Assessment - check the condition of the fuse holder etc. do I feel I'm competent enough to do this? then switch off the main switch at CU to take load off the fuse and just pull the bloody thing and get on with the job, but that's just me - an old retired bloke who's fed up to the back teeth with Jobsworths who won't do their jobs !!!
I find the DNO the most unhelpful people around. Had the missfortune of needing there help twice before both on EICR and both where there equipment is damaged..
if you are going to pull it yourself, just make sure you follow geordie's advice and make sure there's no load going through it. sorry if this sounds bleeding obvious.
by the way, having the level 3 2330 doesn't mean you're automatically classed as competent (i'm not saying you aren't competent - just that there's more to it than that).
good luck with the assessment.
What trouble could a (competant person/electrician) get into if you do break those seals and pull the fuse, if you were to get into any.
Pull the fuse(folowing given precautions)
Do the work
Refit fuse
Get assessment
Get registered
Contact DNO as a Registered Electrician to report the fuse has been pulled and needs resealing.
Reply to pulling my fuse out nightmare in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Been browsing these forums for a while, always great to learn a new way to skin the same cat. Anyway, cut a long story short, was an...
An old and now deceased friend's place has some rewirable fuses with asbestos flash pads. They are long overdue for replacement and now that seems...
Completed my AM2s start of this year. My whole career plan is to run my own company/sole trader. Be my own boss basically. I always get asked...
As per normal I was in a rush and didn't get enough information. I was working in an apartment that didn't have any power and when I went to...
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
