Discuss pump running continuously in the Central Heating Systems area at ElectriciansForums.net
anyone any dealings with British Gas wireless receiver WR1 ?
pump on heating system seems to be running constantly ,boiler seems to switch off but come back on very quickly two zone valves seem to be operating as normal.
pump is running even with programmer switched to off position,I'm just wondering if the receiver is faulty (never encountered one before)
thinking of disconnecting recieiver
The fault is most likely with one of the two zone valves, giving a call to the boiler & pump to run even when they are not receiving a call for heat.
yes I pulled up the manual off the internet,so there should be a 4 core running from the boiler to the wiring ?
I'm working from photos taken by son who is 160 miles away....
The pump is more than likely connected to the terminal marked pump feed. With a voltage indicator it could be checked to see if it turns off or not, when it should.
by the sound of it it appears the pump does not switch off, as he has held his hand on the casing of the pump and it feels like its runnimg all the time, I dont want him taking covers off of anything so cant tell what the connections are
quick update on this,travelled down to visit son and check the wiring out.1st picture is the "wiring centre" 2nd picture wiring centre with cover removed.Ive traced all the cables back and they are all connected as per the s plan for the potterton boiler,the boiler has 4 terminals with the unused terminal being the pf, thats the extent of my knowledge done so as some one mentioned previously its possibly an internal boiler fault (pcb ?) so Im afraid the parts darts master is going to get another go at it....
If the pump is not connected to the pump feed then it’s not an internal fault with the boiler. With a voltage indicator you could check the wiring an see where the pump is picking it’s feed up from when it shouldn’t be.
Ok,got that,but the wiring is correct as per the potterton wiring plan,I'm thinking back to this wireless receiver thermostat thing again,plus I didnt take my voltage indicator pen down with me I don't trust it....I once had a cable where I could see both cut ends and the pen still lit up....
Reply to pump running continuously in the Central Heating Systems area at ElectriciansForums.net
Friend asked me to wire in a hive on a conventional 1 zone heating system. So I fitted it tested the HIVE and all was working. I then said to him...
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
For the past few years, I have used a hydronic system (outdoor wood boiler) with both high and low temp working simultaneously. The low temp...
