Wonder if anyone can help my poor brain on this one...
Situation..domestic, house, 1955, full of every single elec DIY nightmares courtesy of owners in the 90s.
Lighting circuits have no cpc, but in doing a DIY attic conversion at some point, previous owners put pretty metal lights up and a metal switch..oh yay..they want a new CU so going through all the usual checks.. I opened them all, all have a cpc..but in doing a Cont check between MET it was apparent that these cpcs are not actually connected to anything..all open circuit.
I had done the Cont test with the MS off...but I happened to do it today with MS on, but lights off,,,suddenly getting a Voltage reading of 36V between the MET and the metal (and cpc) of each light and switch!!.. With the light turned on reading went up to 118V...same at every light.
Help!! Does this mean that the Cpc from these lights IS loosely connected to something somewhere? (It's certainly not picking up an earth from any sockets etc but I fear many a hidden JcnBox in the property..)
or is this some kind of induction going on?
I should say the MET leads to a Rod as it's a TT..rod of about 100ohm, bonding in place takes the Ze down to about 2.5ohm.
Any ideas much appreciated! Many thanks
