- Reaction score
- 6
Hi all just been to a job where a builder has started a job and left them in the lurch, they have run a 1.5mm flexible cable in a pvc pipe underneath a patio which then comes out through a wall for drive way lighting the run is 5metres, personally I would have done this in swa as In my opinion there is more protection on offer! as the patio is already down they have called me in to connect the lights, im just wanting some advice requarding pvc pipe and running flex underground, what are the regs on this & is there a sufficent cable or specific piping needed for this? Cheers
[automerge]1596463742[/automerge]
[automerge]1596464026[/automerge]
Am I right in saying they should of used THWN Cable thermal heat and waterproof.Hi all just been to a job where a builder has started a job and left them in the lurch, they have run a 1.5mm flexible cable in a pvc pipe underneath a patio which then comes out through a wall for drive way lighting the run is 5metres, personally I would have done this in swa as In my opinion there is more protection on offer! as the patio is already down they have called me in to connect the lights, im just wanting some advice requarding pvc pipe and running flex underground, what are the regs on this & is there a sufficent cable or specific piping needed for this? Cheers
Am I right in saying they should of used THWN Cable thermal heat and waterproof. Buried at 18 inches deep.Hi all just been to a job where a builder has started a job and left them in the lurch, they have run a 1.5mm flexible cable in a pvc pipe underneath a patio which then comes out through a wall for drive way lighting the run is 5metres, personally I would have done this in swa as In my opinion there is more protection on offer! as the patio is already down they have called me in to connect the lights, im just wanting some advice requarding pvc pipe and running flex underground, what are the regs on this & is there a sufficent cable or specific piping needed for this? Cheers
