Discuss Q about PIR's in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
hi there.
Providing your tests at the board are ok (ze pfc I/R) then you need only test 25% of the installation. (if in your opinion, the installation visually is good)
Hope this helps.
In GN3 it says the following:
Where sampling is applied, the percentage used is at the discretion of the tester. However, a percentage of less than 10% is inadvisable.
So I guess it really depends on how bad the Install looks for further investigation?
Warren
Reply to Q about PIR's in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
This weekend at Electrical2Go we are offering the Ansell Prism pro (APRIP/1) for just £6.95 ex VAT ! These are one of our best-selling...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
Hello, Behind a tiny door in our under stairs cupboard we’d like to build a miniature room in which a little light would come on when the door...
