Discuss Question about fuses and power cords in the UK Electrical Forum area at ElectriciansForums.net
A
Analog_out
hi guys,
I am in no way an electrician so apologies in advance But wondering if you could help me out. I've got a little home recording studio and have just copped a new piece of kit (a compressor) for my setup. Unfortunately it didn't come with the power cord. Power cord is just the standard iec 3 pin kettle type cord which I'm planning to plug into the last remaining socket on an 8 gang. Compressor is switched to 230v for UK. In the manual it says to use a 63mA time delay slow blow fuse. Can I just swap out the fuse from the iec cord (I'm guessing it would come with 5amp)? I can't find much on these types of fuses tbh and would rather not fry ****. cheers all
That will be referring to the fuse within the compressor itself, not the plug fuse. If it has an ordinary IEC inlet, a 5A fuse in the plug is fine.
(BTW on this board a 'compressor' is a noisy heavy thing that pumps air - not a dynamic range reducer - and would not work very well off an IEC lead!)
^^^ what he said!
^^^ What he said about what the other guy said ^^^^^ Daz
Reply to Question about fuses and power cords in the UK Electrical Forum area at ElectriciansForums.net
Hello. Had an issue a few months ago with a double electrical socket. One of the switches was stiff and sticking most of the time. I contacted a...
Hi, I'm looking for some guidance from more experienced hands. Have a friend who just bought a 2.2kw air compressor which is obviously blowing...
4K
Just interested in peoples thinking on using the neutral through the earthing system like I came across today. I've come across many wrong...
Hi there Complete novice electrical wise. I am refurbishing an old 1950s Injection Moulding machine and looking to replace the Power Timer...
6K
Hi, just found this forum! I'm in Australia Maybe people here can suggest what may be causing a power issue I have. Appreciate any suggestions...
