Discuss Question from a wetpants in the UK Electrical Forum area at ElectriciansForums.net
Sue1
Can someone please clarify if a plumber with part p and 18th edition who isn't registered with any governing body can change a shower with the same kw as long as the cable is the right size and the fuse, the rcd works and the shower has an isolating pull switch. Cheers. Seems like a lot of confusion.
Part P is a building regulation. The 18th edition is a wiring regulation. Neither are qualifications.
Anyone can change a shower. He/she has to do it safely and of course it should be tested and the results tabulated.
There is no requirement for an isolating switch, pull type or otherwise, as it can be isolated at the CU. Having said that they are usually fitted, but definitely no requirement.
Dunno why there is any confusion. Actually, yes I do - there are outfits out there for whom it's important to their bottom line to create and persist such confusion.
Anyone who is competent to do it (and has the required test gear) can do as you describe, being a member of a scheme is irrelevant as it's never been notifiable to replace an item (other than a CU).
Part P is a freely downloadable document, if he 'has part P' then all it proves is that he can download something from the Internet and maybe even print it.
The 18th edition qualification only proves knowledge of the regulations, it doesn't prove anything about practical ability to do electrical work.
Replacement of a shower is not notifiable work, however it must still be connected in accordance with the wiring regulations and testing carried out.
Reply to Question from a wetpants in the UK Electrical Forum area at ElectriciansForums.net
Hi Folks , Just looking for a bit of advice as I'm looking to get back on the tools so please bare with me if this is a bit long winded. I'm a...
Hi Could someone please help me with how to navigate the 18th edition amendment 2 (Brown) book in the most time efficient way for the exam. I...
Hi Guy's, I'm revising for my 18th amd 2 and came across a question that has me a little confused. I think its probably the question is badly...
Hi I'm looking for some advice for adding a time delay on my parent's shower room fan. My parents had a section of their garage converted into a...
