Discuss Question on kitchin electrification in the UK Electrical Forum area at ElectriciansForums.net
i like the answer but not sure it's pc, and i got slated for putting forward my opinion and giving nothing constructive!!
on a constuctive note; have alook at OSG
To be honest Joe at my age very little I do is politically correct .................................and what will the OSG be telling us it may advise us on how many sockets we could think of using ....but for equipment???
Can I take it from the way you've used the word 'receptacles' that you're in America?
If so all the sockets in the kitchen or utility room should be fed via a GFCI receptacle. You only need one in the room - the rest can be fed from it on the output side.
From the last post I assume he is in Cameroon.
Washing machine, sink and deep fat fryer in my kitchen :)
(oh, and the wife uses a foreman grill)
I suppose you could go trawling through someone's previous posts hunting for clues, but I don't see why I should have to. The way I see it you can add your location for a valid reason other than as a badge of pride.
All the tradesmen and not one mention of the most important kitchen appliance we all look forward to seeing......Kettle!
OK, so in order of priority. 1. kettle. 2. woman ( that takes care of the washing, cooking, ironing, ) . 3 . fridge optional for those who prefer tasteless lager to real men's ale.
Reply to Question on kitchin electrification in the UK Electrical Forum area at ElectriciansForums.net
A close colleague of mine is hiring a Distribution & Plant Technician at Reading, Napier Road depot. Technicians provide the essential link...
Without running new wire or at least ground, next best is GFCI receptacles for limited protection. I know about a bootleg ground to fool a tester...
I am replacing some of the old receptacles in a 1940s house. Armored BX cable, two conductors, cable is the ground. Mostly pretty straightforward...
A 13-year-old GFCI kitchen receptacle went bad, so I replaced it with a new one I bought from Lowe's (Eaton model TWRSGF20). After one day, this...
