Discuss Questions regarding metal gang boxes in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone!
I am an industrial designer working from Israel, currently working on a product that will be installed in american homes and needs to fit into a one-gang box.
I'm having trouble figuring out how common are the metal boxes out of all the home-installed electricity box,
(professional installation, not DIY), maybe someone can give an (obviously rough) estimate?
30%/40%/50% of the boxes are metal?
Also, i found that there is a (very) wide variety in gangbox models, could someone point out which is the most common?
Many many thanks!
Or Lev
think you'll need to wait till some of our american members come online. those boxes are notanythinglike we have this side of the pond.
@NekudaDM you may be better off posting this in the American Forum
Or report this thread and ask for it to be moved.
Hi everyone!
Many many thanks!
Or Lev
@nekduaDM since they will be installed in existing homes I would just go with the plastic boxes, you don’t have to ground plastic. Good luck
@Megawatt the product I'm designing will have to fit into exisiting boxes, so what I'm trying to find out is which boxes are more common
Nekdia in the USA and I’m not speaking for other countries but the blue plastic box is used in homes that is built with wood studs the TP122 is used mostly in commercial installations where there is metal studs. If I were you I would design it for the blue plastic boxes.
Reply to Questions regarding metal gang boxes in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone, Following on from my previous post where I received advice on taking a spur off a 40a feed (thank you). I performed the work...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
Hello all. First post. DIYer. Know enough to be dangerous (LOL). It seems "standard" blue PVC boxes here in the US are 2.25" wide and depth can...
Hey, question for the group on grounding when using MC cable and metal boxes.... Situation: Enclosed a carport and turned it into a garage. I'm...
