N
nazoom
I am trying to find out where on the light switch or the celling rose of a light is the test for continuity and polarity are carried out? If continuity is carried out for a light circuit then where the probes connect to? is it on the switch line and the cpc at the ceiling rose or the brown connection and the cpc at the light switch?
Also for polarity test where is the test carried out at the ceiling rose or the light switch? If on the light ceiling rose then where do the probes connect? is it on the Cpc and the switch life connection? Or if it is carried out at the light switch then where does the probes connect to?
Many thanks.
Many thanks.
