Discuss Quick check sheet review in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
O
oldtimer
Hi all with regards to the Quick check sheet I have made up first of all anybody using it and secondly any advice on how to make it better . It may not be everybodys cup o tea but I use it as a crib sheet ie fill in the boxes and transfer over ie working copy . Yep I have bluetooth on my 1553 but its not economical for me to use it so happy to modify and also remember this is just a condensed sheet for using on site.
View attachment quick checkrev2.pdf
all i'd do with that is try and make the circuit ID column a bit wider. also at bottom. RCD is 61008, not 60947,
Would it be worth putting a box in for a global IR reading? It's one that's on our SA domestic compliance test sheet but not sure if it's a standard test in the UK, obviously it should be equal to the sum of all the individual circuit IR's.
Yep was thinking that but where do you stop hence why the notes section so if you do a LN---CPC you strike out L-CPC you note it
Reply to Quick check sheet review in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
O
Hi Guys I dont know if this is any good to you or that you may use it but I have updated my quick check sheet for I&T I use this as a working copy...
T
B
Ford Transit T280S Van For Sale ONLY £3990 NO VAT New Shape 57 Reg Dec 31 2007 Short Wheel Base Medium high roof 75000 genuine miles MOT end...
BlueToBits
B
