Discuss quick Q re kitchen grid switch in the UK Electrical Forum area at ElectriciansForums.net
J.C.E
Evening chaps
just quick one
looking at a job to do some bits- and rewire kitchen is on the to do list...
clients got me doubting myself now- even though I know I am right (well 99.98% now lol)
he wants the under unit points- isolation above at a central grid switch which is fair enough
so he went on to says 8way switch (4 switches and 4 fuses)
I told him you only need the dp switch for isolation purposes and the fuse is only needed to down rate if needed...
Was planning on running my ring through 4 of the dp switches (supply side)
and then spur off each dp switch in 2.5mm to the associated socket underneath (from load side)
and just have a dp switch AND grid spur for the the boiler- so just use a 5way grid (4x dp sw's and 1fuse)
spurring once off of the dp switch is no different from spurring once off of a outlet right...
I have just done one and used fuses in the grid switch assembly, but I terminate into a connection plate behind the appliance rather than a socket and ahrd wire the appliance into that; then if the fuse does go I can easily replace it without dragging the associated appliance out or having to partially dismantle a built in appliance...my 2p worth...
Reply to quick Q re kitchen grid switch in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone, I'd like to seek your input on a matter. I'm in the process of designing the electrical connections for the following kitchen...
Double wall socket switch won't switch off. It just flips back to on. The left side one is fine. It used to do this 3 years ago then was working...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
