Discuss Quick switch question in the Australia area at ElectriciansForums.net
Dear all,
Just started training to become an electrician, just done first week practical, made copious notes but not on the following: On a lighting circuit, when the feed comes into the switch first and then to the lamp, do i need to use 3 core to go from the switch to the lamp. Presumably the switched neutral and the live both go into the live bit of the lamp, if using 3 core, i guess the grey would go into the lamp neutral (with blue sheath) to complete the circuit. Apologies if this is really obvious but my brain hurts and I would appreciate some help
Down2Earth
Im pretty sure you would use 1.5mm Twin & Earth, both live and neutrals become switch wires (neutral needs brown sleeving to represent it is live).
Then the neutral goes into the 'N' point on the ceiling rose, and the live goes to the loop section I think?
Can anyone confirm this?
TWIN & EARTH 1.5mm to the switch (from supply) and the same to the lamp.
Dear all,
Down2Earth
you never switch a neutral, im not sure what your asking - I think you need some lighting diagrams and speak to the people you have worked with all week.
you would not need a 3core and earth as a bulb only needs a live and neutral(all cable must a carry an earth- usually..excluding tails,lv...)
are you taking the feeds to the roses or switches?
the feed is coming in to the switch first, then to the lamp, whats confusing me is the lamp in question only has neutral and live (plus an earth connection), whereas the lamps we have been working on all week have the neutral, switch live and live blocks. I will try and post a picture to better explain what I'm on about.
Down2Earth
The lamps have a 4 way connector block, so that when a 3 plate is taken down, there is somewhere to terminate all the cables.
Live, Sw live, neutral and earth.
im a bit confused what your asking but il try and explain...
right the 2 main ways of wiring lighting
method 1 loop in & out of pendant
method 2 loop in and out of switch
method 1
from consumer unit in 1.5 t+e to first pendant, then 2 next etc etc... then from your pendant you take a 1.5 down to your switch... brown to common blue ( sleeved brown ) l1.
method 2 ( which i think your talking about )
from consumer unit to switch box, then from switch box to next box etc etc, then from switch box up to you pendant.
now because you have a permenant live neutral and earth at the switch, the 1.5 you take to the pendant goes to switch live neutral and earth.
kinda hard to explain really much easier when you can see it
hope this helps
Bahco's Method 1
The cable you see going to the Ls (Lightswitch) is just basic Twin & Earth, however because both sides will be live at some point you must sleeve the blue with some brown sleeving to indicate this.
For a lighting circuit you usually use 1.5mm2 or 1mm2 cable. In a lot of old installations the switch wire and feed was done in singles so you may find 2 red cables.
Method 2 is what I do now on installations. I have the Feed P/N/E inside the switch and then take a switch wire upto the lamp. Inside the switch itself I have the Feed Live (Phase) in the common, the Feed Neutral in a terminal block and the Feed CPC (Earth) in the backbox terminal with a jump lead to the switchplate if required. Now I have the Load Live in the switch L1 , the Load Neutral inside the terminal block and the load CPC with the Feed CPC. This cable is then run to the lamp in twin & earth (Live/Neutral & Earth).
I usually only use 3core when making 2way or intemediate switches or if installing an extractor fan with a permanent feed.
Hope this helps.
I have hopefully attached a picture with the intended wiring. Live feed coming into the 'com' and the switched live going out from L1 to the lamp with the two neutrals connected in a block. Ignore the strange looking earth wires, this is just a mock up on a practice board in the garage. My question is, is this correct for a feed coming straight into a 1 way switch and then out to a lamp (in the loft in this case).
Thanks for any help
method 1
hope this helps
Instead of sleeving the neutral why dont you use twin brown+earth and lighting circuits can also be wired in 1.omm on a 6 or 10 amp mcb.
as your pic shows, you are permanently connecting the neuteral to the lamp and breaking the live with the switch, when wiring like this, the centre terminal block in the ceiling rose is not used. just as eskimo says. this is method 2
the twin brown vs brown and bue (sleeved) debate has been had before. I always use twin brown. a lot of guys on here say they can't get twin brown in their wholesalers. I think it is a better job. it seems to be used more here in Northern Ire than in England.
Twin brown on the mainland is as rare thing for some reason don't ask me why.
If i need it i normally get it couriered from back home or direct from doncaster cables.
You will get the hang of it,they will probably cover 2 way and intermediate as well,i did read in the press this week that there are currently 100,000 people on electrical training courses in the uk at present,its number one must be all the promises of 50k a year,the people running these courses and charging between 3-5k and sending the "qualified electricians" out after 2 weeks,some(not all)maybe dont have an idea in the real world,the providers have a lot to answer to,i just think these guys and girls are getting scammed of there money.
Indeed. I've never seen anyone here use brown & blue instead of twin brown (or red & black instead of twin red in days gone by).
Doesn't bother me that much because 75,000 of these people are getting sent to the Isle of Wight to work:rolleyes:
Only joking Rob.
Reply to Quick switch question in the Australia area at ElectriciansForums.net
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
Howdy DIY soldiers, first post here. My question comes down to whether it would be particularly unsafe for me to temporarily wire nut and tape a...
Hello I have an old timed extractor fan in the bathroom which has stopped working. It has 3 wires which are black, brown and grey. I believe that...
Hi guys, first time posting, please bare with me! I have an old test chart as shown in the pics that i would like to get running. Everything...
I'm using the power to switch method for three kitchen pendant lights that have 3 switches with 1 intermediate. I'm using 3 Core for the switching...
