Discuss Quickwire Splitter function? in the UK Electrical Forum area at ElectriciansForums.net
It's a light splitter from Quickwire. The Switch & Load is a great alternative to a light junction box, just don't see when you'd need a splitter, couldn't you go from light to light without it?
That's the only use I have determined for these so far.I really like these.
They would be good for when a customer buys one of these light that just come with a 3 way terminal and not enough room to put more.
I’ve used the quickwire splitters on several occasions when installing multiple downlights, only need to use 1 power feed cable, then split this out to as many lights as required, using multiple splitters as required.
Reply to Quickwire Splitter function? in the UK Electrical Forum area at ElectriciansForums.net
