Discuss Quinetic wireless units - power reset in the Electrical Forum area at ElectriciansForums.net
Does anyone know if quinetic wireless units (switches/receivers) retain the memory after the power is cut, and if so for how long?
Instyle LED Lighting Specialists UK
happysteve
I've never known one forget their pairing. I've never had a call-back. When power is restored, they always revert to the "off" position (which is useful for getting the switches the right way up).
pirate
I agree. Never had a problem with the pairing being forgotten...except if some extraneous signal has interfered, which has happened to me a couple of times on my own home install. (Speaks volumes, that!)
On other sites, I have never seen a problem. As happysteve says, they default to off normally.
Reset is only a problem if the receivers are tucked away. I try to install them in the loft, side by side, clearly labelled...not always possible, i know, but if you do get outside influences it is easy to re-pair.
Not worth worrying about, imho...just enjoy the freedom they give.
I'm in agreement with the others. Never had a problem with reset. Have installed loads for clients and have them at home too, linked to Alexa (god forbid the kids have to get up to turn their lights on). I'm always turning off power for one reason or another and they've never become unpaired.
pirate
I would add that the nice people at Quinetic provided me with a neat demo unit, and this sits in a box for weeks at a time, disconnected from the mains. When I set it up, the switch is always still paired. Customers love it!
(The mains cord supplied is however, one of the awful ones from t'internet)
  • #8
Thanks again all. A customer wants 6 of these fitted rather than channel out her walls.
Just to clarify, I do recall reading on here a while ago someone saying that occasionally the switches can end up in the wrong position, not of course an issue for 2 way lighting, but not great for one way switches. When/if this happens, how is this corrected?
SparkySy
I have fitted 4 in the same house before with no issues. if that happened you just switch the switch the other way and it should sort itself out!
I've fitted hundreds of them over the years and they are bulletproof, only had 1controler die on me and that was because the customer added more lights without consulting me and the unit was too small to switch the load.
I have had 1 switch fail 5 years after I fitted it and that was I think due to the amount of times it was used( on a farm too)
happysteve
Two ways:
(1) Turn switches to "off" position. Turn off power to circuit (i.e. at circuit breaker/RCBO). Restore power. Now, "off" is "off".
(2) Flick the switch on-off really quickly. If you're fast enough, the receiver only registers one of the switch actions, and the switch behaves the other way round.
If all else fails, flick the Mcb for the circuit, pop the switch in correct position and energise the circuit again.
If you're putting in the WiFi models you can just turn on/off from app or alexa or whatever you're using, and the switch will remain in whatever position it was left in.
Two ways:
Sorry Steve. Didn't see your reply mate.
FatAlan
Trainee
They've been singing their praises on GSG electrical or efixx on youtube. Going to have to have a play.
CK Tools :) The professionals choice when it comes to Electrical Tools
Reply to Quinetic wireless units - power reset in the Electrical Forum area at ElectriciansForums.net
SuperlecDirect - ElectriciansForums.net Electrical Suppliers
Top Bottom
