Discuss R,Y,B or L1,L2,L3 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all,
got an EICR to compile and I'm just wondering whether I should be using L1,2 and 3 on schedule for identifying circuits or just stick with R,Y and B since it has been marked up like that on existing schedules etc?
i'm with trev on this one. label with both. i call it BS and AS (before stupidity and after stupidity)
To be honest, it depends on what's there for me. If its an old DB, then I will keep the RYB designations, but if it's new then I use L1, L2 L3 with the way number in front
But by using both you're complying with current regs and making it idiot proof. You could get someone coming in after you at some point who sees the coloured lines and has a head scratch wondering how the colours equate to L1 L2 etc.
Well thats why you use the dual wiring colour sticker at the DB.
But you should still be recording 17th edition terminology in the report.
RYB went out in 2006 , time to move on :)
In fairness I don't think identification of ways comes under BS 7671 terminology. Certainly for new work I'd be using L1/L2/L3 but as johnboy says I might be reluctant to alter what is already marked up as R/Y/B. It may cause more confusion than it eradicates.
I would go with Trev on this one.
You could also put in the recommendations that R = L1, Y = L2 and B = L3 just so the new wave of sparkys don't confuse blue with neutral. As above, idiot proof.
So what do you do if you're working on one circuit of an existing 18w board ......
R12, Y12, B12.....13L1, 13L2, 13L3.....R14, Y14,B14. Your cert schedule has to match the db, surely. Don't make it more confusing. With Trev, best of both worlds.
You should be using L1 L2 L3 for everything, what would you do if your sub-main cable was an old red phase supply that feeds a new coloured DB.
Dont make it more confusing ? its not confusing at all if everyone follows the current guidelines.
Reply to R,Y,B or L1,L2,L3 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Wouldn't normally note this as an observation on a report but feel I need to. The way the building has been wired is all circuits on L1 have been...
Hi Guys, sorry if posting in the wrong section. I am due to start 2391-52 course soon, and there seems to be from what I have found out, a 3 phase...
Ok, i am new in this forum I am looking for some enlightenment. Today I got a call from my boss, which is now in Venezuela and he is connecting a...
