Discuss r1 & R2 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Just installed some downlighters with e.l.v transformers have done ins. resistance & earth loop before connecting transformers.Readings acceptable but oops!! forgot to do r1&r2 test.Can i still do this test now i have connected transformers without false readings or doing any damage???? Help would be very much appreciated.:eek:
Reply to r1 & R2 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I have been asked to look at this report as the customer has been given (in their words) 'A very high quote plus VAT'. It doesn't look well...
Hi forum, A question about R1+R2 testing. I’m testing a lighting circuit. It’s an old circuit with old colours. In the control panel feeding the...
Hi Guys, sorry if posting in the wrong section. I am due to start 2391-52 course soon, and there seems to be from what I have found out, a 3 phase...
Hi Can anyone clear up or explain in a bit more detail what could potentially be causing the results I have. I have just tested a 32a ring main...
