Discuss Radial vs Ring in a standard 3 bed in the Electrical Forum area at ElectriciansForums.net
Afternoon all.
I normally cable my first fixes in a standard 3/4 bed as follows:
Ring up
Ring down
Kitchen ring.
I was at a trade show the other day and got talking to a few people and they said they only use a ring in the kitchen. Radials up and down. Got me think what’s the standard? I know there’s a max length for a radial circuit even though i can’t remeber it as I don’t normally use them. What do you guys use as I’m on a first fix atm and taking a leg back to the board from my upstairs circuit is going to be hell.
Cheers
Afternoon all.
Ring up
Ring down
Kitchen ring.
Cheers
What size radial 20Amp or 32Amp are you referring to? or I think, alliterating to.
Surely if you were going to use a radial for up and down then you would need more than one radial for up and more than one for down? Easier to run a ring for each! Not a lot of saving when you think about it unless there is some other reason of course?
To be fair, what modern 3 bed house needs a 32A ring these days! Litrelly everything is low wattage. As for your question, id install a ring for all 3, still not sold entierly on 4mm radials
Having just read my fuel bill, averaging £90 a month for lecy (we got gas heating), I need to run some bigger cables.
our pad has 2 radials for the whole house. this was because it was rewired about 20 years ago by Mrs.Tel's dad and brother, (both Polish with no conception of rings). in 12 years i been here, new CU with RCDs added by me, not had a trip except when a bulb has blown.
My kitchen has been running on a 16A ring or 8 months and not tripped yet. I miscounted breakers and cant be bothered changing it.
Washer
Tumble Dryer
Microwave
Kettle
Air Fryer
Toaster
You will be amazed at how little more than 2 items are used at once
why would you want to fry air?
My current 3 bed 1980s semi has 1 ring on a 32a mcb for the entire house. Like this from new I presume. Not been rewired.
In fact it only has 4 circuits in total.
Cooker , ring , immersion and lights.
Proteus split board , cooker , immersion and lights non rcd And ring on the rcd. Loads of spare ways.
Reply to Radial vs Ring in a standard 3 bed in the Electrical Forum area at ElectriciansForums.net
