Discuss Radio link smoke alarms in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
K
KEVINDOE
Hi Guys
Got a loft conversion going on soon, i would like to fit radio link alarms on ground,1st and loft level..prob is, all 3 floors are on a different lighting circuit,
Is this ok to connect from three different feeds ? or as i suspect , they should all come off the same circuit ?
Any help welcome
Jemma
3 feeds is ok, that really is the point of them otherwise you may as well run in new cabling. I would mark up the CU clearly to identify which ccts have smokes on them.
Reply to Radio link smoke alarms in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I’ve recently moved into house and had an electrician out to install some new lights and shaver point in an en-suite. Problem is that the house is...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Not come across this before, so would like some help, please. I went to install smokes and heat alarm (to new Scottish regs) in a fairly modern...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Hi Im an apprentice and just wanted to clarify domestic style wiring since i work industrial and don't deal with conventional wiring. in college...
