Discuss Rafiki fire alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
sparkie-leeds
Hi All,
I am installing a rafiki 2 wire fire alarm system shortly, is it important to mark the cables going into the detector bases as "IN and OUT" or does it not matter with it been a 2 wire system.
As previously mentioned, ALLWAYS mark your line "in" at every point regardless of system type. Not only is it good practice but if a fault occurs it's so much easier to find by simply splitting the circuit and putting your eolr across the "in" leg.
Modern two wire and twinflex systems have the eol built into the detectors so the last point has to be set as "end of line" by using the dil switch.
You'll find that when you check the bases out, they are marked as IN+VE and OUT+VE with 0V being common so it is important to mark your lines.
i just slap a bit of tape round the IN when 1st fixing.
Reply to Rafiki fire alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
Hi all, i'm just after a definitive answer regarding a fire alarm system in a communal area/stairwell. There are call points, smoke heads &...
I'm installing mag-locks and fire door hold-open magnets at the moment and I'm wondering if any of the cable should be fire performance cable...
I'm about to order this wired smoke alarm system as it can network but I just went to see how my existing fire alarms are hooked up and there...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
