Discuss Random socket tripping in the UK Electrical Forum area at ElectriciansForums.net
Hi,
Our breaker box is located in the cellar. We experience random socket trips throughout the year. Summertime seems to be the best when we can go months without an issue.
Autumn/winter time is awful. We have had 3 trips within the last 24 hours. No new appliance has been switched on when the trips occur.
Could it be a faulty RCD? Is it the location of the breaker box? Please help.
Is there any signs of condensation on the consumer unit or in the cellar?
If you have a dehumidifier you could try putting that near the consumer unit and see if that helps.
Hi Fuz and welcome to the Forum:) .
Repeating trips don't happen for no reason and aside from the inconvenience to you it could be a fault that's getting worse and so may become dangerous at some point. If it's not related to an appliance then as Buzz has advised, I think you'll be best served by getting your local friendly Electrician around to have a look. Most do "attend and work for an hour" callouts. Someone here may be nearby (?).
The lights are on a different rcd and the only outside socket has a built in rcd which is tripped when not on use. May have to bite the bullet and get the sparky in
That socket is most probably the problem.
Moisture inside will still trip the circuit RCD even though the socket RCD is off.
Fuz, what actually trips, is it the RCD for a set of mcb’s, or is it an individual mcb that keeps tripping?
If it’s the mcb, is there a label below it that says what circuit it’s protecting and what is plugged in to the sockets of this circuit?
Yes it's the rcd that protects just the sockets. Everything else stays on.
haha.. wish you would have put this in your original post mate.
Does look like the outside socket is causing all the trips then... but can't be 100% sure, unless you get someone to look at it.
The outside socket has a built in rcd. When it is not in use we trip it on the outside socket itself.
But if water is getting into the outside socket it will still trip the RCD in your board.
The socket RCD will only protect what is plugged into it.
Reply to Random socket tripping in the UK Electrical Forum area at ElectriciansForums.net
I have an issue with a home lighting circuit 6A RCBO provides power to 13 bulbs which randomly keeps tripping, when I say randomly it keeps...
Hi, I seem to have an RCD that keeps cutting the power at random times without actually tripping, if I reset it, the power comes on and will stay...
Hi I am asking for help as a novice and 1st time user of this forum. Recently started to experience tripping of MCB & sometimes with the RCD at...
Woke up this morning and tried to turn on the computer (work from home) wouldn't power on, checked lights they worked fine. Went downstairs to...
