Discuss Range Rover L322 Webasto heater GSM switch help please. in the Auto Electrician Forum area at ElectriciansForums.net
B
Badger boy
Hi everyone,
In the rear of the RR is the plug which connects to a remote controlled unit a telestart t90 switch box of some kind, a telestart t91 fob is required to operate the unit. These fobs are a fortune on ebay as it has to be the earlier type which are quite hard to find, one went the other day for £130 for the fob alone. For both bits of kit it could be between £150.00 to £200.00
It is basically 3 wires in the back of the vehicle as follows which would plug in to the remote unit
live feed
earth
relay on (supply out)
I have a GSM relay (£17.00 Ebay) which i have already set up on my workbench, I have tested with the sms messages and I can switch on the relay for 30 mins etc which will communicate with the heater to run. The heater is setup within the vehicles ECU to run for a maximum of 30 mins to save starting power for the main battery.
As the GSM relay is permanently live it draws approx 50 to 100 mah all the time, I wanted to install a small 9ah battery I have which will power the gsm relay at all times. My RR battery is 950ah and I know you may think this would run the gsm unit for approx 5 months anyway before flattening the battery.
The RR electrics are such a pain in the bum if it doesn't have a fully charged battery, EAS suspension lights etc, ABS braking lights. hence my reason for the additional small battery. I only travel for a maximum of 15 mins each way to work.
I do not want the small battery to assist the large battery when the vehicle is starting though so the use of a diode i think, and I would like the vehicles electric to supply a controlled supply of power to the small battery to sort of trickle charge it at say 1-2amps when the vehicle is running and not at the full power available from the alternator which is rated up to 150amps I think.
is there such a single component that can deliver one way and trickle charge or a ready made component available that I am unaware of.
I hope that makes sense, I have a made a diagram as well which may not contain the correct technical terms but hope it helps. The drawing does not show any fuses however these will be included when I install the relay.
Thanks in advance for any help or guidance you may be able to offer.
David
If you have a socket outlet nearby you can connect a battery charger, such as an Optimate, to supply and maintain your battery whilst parked up. This can either be connected directly to your battery or through towing electrics. I use a CTEK MSX 5.0 on my Discovery.
I've got the same charger which I use mainly on the bike, but sometimes on the car. That's a good idea using the tow bar socket to connect it. Do trailer sockets have a permanent live to them?
Come to think of it, I haven't got a towbar, but still an interesting idea.
On the bike I connect it via the 12v aux socket using a cigarette lighter type plug.
Hi thanks for your reply, I can not always get my car close enough to the house so a ctek charger is not an option ?
Reply to Range Rover L322 Webasto heater GSM switch help please. in the Auto Electrician Forum area at ElectriciansForums.net
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Looking for advice for how much power I can reliably get from a dual battery system please (note it will be installed by a professional, I am just...
Hi all, I need help/feedback. I am modifying a machine. I have added an aluminium profile frame (enclosure ) to a machine (the machine will be...
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
So I run a small group of 2017 Ram 1500 4x4 pickups, that have an electrically powered hydraulic pump installed on them for a hydraulic probe...
