Discuss rating of RCD in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
U
UK sparks
Hello guys
Ive got a transportable weather testing station that has mainly electronics in it with two racks of 13amp sockets for the computers to run on. The fuse board in the unit is part of the factory fit and has a 300 ma rcd protection the unit is based in a rural location with a TNS supply and a earth rod has been fitted. The unit is also backed up by a generator if required.
Can anyone confirm to me that the 300 ma rcd is ok as I'm sure the regs stat that it should be 30ma but cant find the reg on it.
many thanks
i'd speak to the manufacturers on this. it may be that the 300mA RCD is there mainly for fire/fault protection and they have considered leakage problems with computers and electronics.
The 300mA RCD is probably for fire protection only. As only trained/instructed people will ever be able to access this unit, it'll probably not need 30mA. 30mA may also be far too sensitive for all this computer related electrickery, as far as nuisance tripping in remote locations goes!! ....
Agricultural and horticultural premises require protection by 300mA rcd for fire protection as already pointed out. Sounds like this building has probably had a change of use since then.
many thanks for the reply good idea I will email the manufacture and get there info thanks UK sparks
Reply to rating of RCD in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello Need to replace a distribution board in the next few weeks to allow for more circuits to be installed in January. Existing is a TT system...
Hi all, Grateful for your expertise regarding my confusion on the below. Context: French rural domestic property Single phase supply, TT...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
Hi friendly people, As you may be aware, I'm a plumber, so quite possibly what I am seeing is correct, though it seems a bit odd to my untrained...
5K
I quite often contribute on other's posts about issues with RCD's, thought I'd tell you about what happened to me yesterday as a little bit of a...
