Discuss RCBO keeps tripping - without explanation in the UK Electrical Forum area at ElectriciansForums.net
P
pads
The wiring in the house is split into separate circuits each with their own RCBO for
3 for lighting (separate for ground floor; upper floor; and basement)
3 for power (again as above)
1 for cooker
1 for shower
2 for fridge/freezers
The problem exists only on the ground floor power circuit.
Whenever the vacuum (two core) is switched on in any socket, the RCBO trips. It's not the vacuum as it dos not happen on the upper floor. I have even tried an angle grinder- thinking maybe induction issues - but it does no trip.
Occasionally the circuit trips on its own, or if the computer is switched on.
I've checked all the sockets for damaged or trapped wiring, but nothing found.
Does anyone have any suggestions please.
Peter
Sorry, take that back, doesnt hep you with your problem! But more info on testing done is needed to be able to assist further ....
All outside circuits are on a separate CU entirely so they should not affect things.
I have unplugged or switched off (where via switched spur outlet - DP) all items on the same RCBO.
And the RCBO stays on for about 2 mins or little more then trips. Without doing anything. (Yes even the boiler is off)
Peter
Retired electrician.
Yes have some test gear - insulation tester, multimeter. Plus a brain which cannot get its head round this one.
The only thing which has been done recently is some decorating. but checked all sockets for trapped wires under screws.
Mate.... have you disconnected the circuit and done any tests that would indicate as to what the fault is or where its likely to be????
Disconnecting the circuit and doing full tests is the job tomorrow.
Just thinking - the main feed to the house is through the cellars of the two adjoining terrace houses. If they disconnected the earth could that cause the problems?
I would have thought though that there would still have to be a fault in my wiring to cause the symptoms.
Who knows, because until you get your test kit out we haven't got a bloody clue what's actually do we?
so do us a favour and reply when you have some results if you have been unable to find it.
What sort of spark were you?
1 for cooker
1 for shower
Peter
So its when the vacuum is switched on???
But its not the vacuum???
Or is it the computer??
Reply to RCBO keeps tripping - without explanation in the UK Electrical Forum area at ElectriciansForums.net
I have an issue with a home lighting circuit 6A RCBO provides power to 13 bulbs which randomly keeps tripping, when I say randomly it keeps...
Hi, I moved home a few months ago and the electrics RCD keep tripping. Sometimes it will happen every few days and sometimes will be fine for a...
7K
Hi all. We have a 120v 20 amp circuit to an accessory dwelling with a run of about 75' of direct bury #12. The breaker keeps tripping even when...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
