Discuss RCBO Neutral Leads bunched with Main Neutral in Main switch - C3 or C2? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
So these conductors are bunched along with the supply neutral at the main terminal and not the neutral bar, does the board have a main switch.
Hi, a previous engineer has I assume carried out a test and the 1st two circuits, Fridge and Smoke Alarms, they have decided to put these two on RCBO's. The board only has two Neutral bars for the two RCD's (this is a dual RCD board) they have terminated the neutral leads in with the 16mm Tail incomer in the main switch?
Ah I get it now. What has been done is incorrect, the consumer unit has been altered beyond the manufacturers instructions and the main switch no longer fully isolates the neutral conductors.
Reply to RCBO Neutral Leads bunched with Main Neutral in Main switch - C3 or C2? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
Hi guys, We’ve had a new CNC Machine from China arrive this week. It came with a monitor and a tower to run the software. The monitor and tower...
Hi, Ignoring the appauling conductor terminations which I found, in the background of the photo you can see a really odd neutral tail terminated...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
Hi guys I was recently ask by a customer if/how his house could be supplied by his electric car. He wants to charge the car at night on low rate...
