Discuss RCBO trip. in the UK Electrical Forum area at ElectriciansForums.net
Got a large rewire ongoing at the minute. Owner wants to use current sockets alongside the new board as he’s living in one part of the house whilst the builders are in. Today the old supply was disconnected and whilst cutting through an old cable not connected to any of my new legs the RCBO tripped on the new lights. I tried it several times and same result. It’s not a problem, I’m just curious why. The only thing I can think of is that both the old main earth and new were still connected at the meter. If that is the case then why only the lights and nothing else.
would a dual rcd in place and on the rcd that cables that been cut ,me I would only put a
a temp supply for the builders only ,has for the owner that lives their then he would use it has well.
like I say it’s more curiosity than a problem. It’s a tns system. I have to do it bit by bit as there’s a large family living in it and they need power. The only issue is as I go round cutting off the old sockets and lights my new rcbos are tripping. More of a pain as a problem as once it’s all cut out it won’t be an issue.
If a new adequately sized main earth is installed (who installed it?) I’d remove the old and see what happens.....can’t get my head round how it would cause the rcbo to trip though but I’ll hang around cos there a lot wiser people than me on here and I’m as curious as you now
Possibly a poor neutral connection on the supply side of the installation.
Both main earths were still connected.
[automerge]1576306260[/automerge]
Basically, I was in a mad rush to get the lights on as I was loosing the daylight. I got them on, pulled the tails from the old supply and left the main earth so I could crack on with the sockets. ( needed to get the sockets on before owners came back ). Then whilst cutting off an old socket the RCBO on the downstairs lights only tripped. It was because the old main earth was still in at the board but like I say from my initial post, I was just curious why only the one RCBO tripped as everything else stayed on.
Hi Munders, please clarify:
So far you have installed a new CU
disconnected the tails from the old CU and connected them to the new CU
Moved some, but not all, existing circuits over to the new CU
Not rewired any ciruits
is this correct?
I'm with PEG on this one, I can't see how this could be happening without there being some kind of connection between the old and the new circuits. A segregation test between them is in order.
Reply to RCBO trip. in the UK Electrical Forum area at ElectriciansForums.net
Hi, I have just replaced an old rewireable fuseboard with a 10way consumer unit with rcbo's fitted. The issue i have is that when i connect one of...
I have an issue with a home lighting circuit 6A RCBO provides power to 13 bulbs which randomly keeps tripping, when I say randomly it keeps...
Hi all, Wondering if you could offer some advice please. I carried out a small outdoor lighting project today at a commercial property. 4 lights...
Hi Guys, Had a call out today about an odd issue with a newish Creda DT storage heater. Basically.. Storage heaters were installed in one flat...
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
