albi
- Reaction score
- 7
hello every one i have a problem. i have been called out to a commercial kitchen where the 16A b type RCBO keeps tripping when you turn off a 20A DP switch that controls two dimmers which in turn supplies 2 sets of heat lamps
300w x 5 halogen lamps and 250w x 5 inferred ES lamps.
when the inferred lamps are turned off it trips the RCBO but only.
the inferred at present are not on the dimmer as dimmer is not working
I have tried having only the inferred on but trips cable bells out fine so now scratching my head
