Discuss Rcbo in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A
alibabajany
Dears
Are RCBO used in 3 phase loads, and the other question is about using RCBO for loads located in hazardous area, is it an obligation or not
Regards
a bit of an ambiguous question. RCBOs would be used for additional protection as and if required. regs. in your neck of the woods may be different to ours here in the UK.
Hi ali, you state you are an Electrical Engineer, you question is very basic in regard to your level and it also scares me that you question concerns the use of RCBO's in hazardous areas, I must recommend you call in a competent Engineer to answer your questions, at the risk you are asking this advice to do work on Hazardous area installs I am closing the Thread as you should not be asking such questions through a Forum if you are involved with such work.
-Find a local Engineer to Tehran to advise you as our regulations are British Standards and you will have your own local standards to follow.
-Strict rules and regulations apply to circuits in hazardous areas, you should have a full working knowledge of these regulations if you are involved with them and not asking such a question as above.
For these reasons I am closing the Thread ...Sorry!
Reply to Rcbo in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi All I'm new here. I have just finished my NVQ and waiting to do my AM2. I have a question on selectivity as it has always slightly confused me...
I have a ring cct (2.5mm ) in my cabin which is protected by a 20amp RCBO. This has been in existence for over 3 years with no issues. I recently...
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
I am a retired electrician and I've been out of the game for a while. My son asked me a question the other day and I wasn't too sure how to answer...
So I had an inquiry to make an electric panel (single phase) with RCBO, but it seems like our customer uses type C and F power plug (I live in...
