Discuss Rcbos and mcbs split load board in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
I'm reading this like the CU has RCBO's and then a MCB for an armoured cable going to the garage CU, which has a RCD.
Looks like we will have to wait for the Op to come back and clarify things.
I like to think I have a good imagination.
The way I'm thinking this is, the CU can't be a dual RCD CU as you wouldn't add RCBO's to something that already has RCD, not the same type anyhow..
I'm sure the OP will be along any minute now, to say my thoughts are correct, to which I will then dance around the living room while pointing at you guys and singing "Told you sooooo" over and over again...
I'm always right.... just ask the missus....
Hang on a sec!
You're not the OP are you? That would be really sneaky and cheaty but also very funny and clever.
I don't have the intelligence to do that...
I really am LMFAO... Someone agrees with you.
Reply to Rcbos and mcbs split load board in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
