B
Barry Cade
Excuse my ignorance,can someone explain to me the problems of using RCBO's on a TT system,and whether and why its unsafe
Discuss RCBO's on TT system in the UK Electrical Forum area at ElectriciansForums.net
No problem at all on a single phase TT supplied cu, so long as there is a DP main switch also in use on the CU.......have been fine on my assessments up to now.
The argument given by some is:
There is a requirement for DP disconnection for isolation purposes, the main switch covers this nicely.
A main switch will not clear a N>E fault
There is a requirement for all live conductors to be disconnected under fault conditions, the SP rcbo does this fine.
Others will argue (correctly) that the neutral is also a live conductor and as such should be disconnected in the event of a fault, a single pole rcbo does not achieve this.
On a three phase TT supply all three phases & neutral need to disconnect under fault conditions (not got regs to hand so cant give the number)
I think there are only a couple of companies that produce single module double pole rcbos at the moment, I predict there will be a few more companies selling them in the coming years.
PM sent with detailswho makes compact rcbo not clever
Reply to RCBO's on TT system in the UK Electrical Forum area at ElectriciansForums.net
