Discuss RCBO's in the Electrical Forum area at ElectriciansForums.net
Status
Not open for further replies.
Richard
Regular EF Member
Morning all, and happy easter!
Right, generally speaking, how much are you guys paying for RCBO's at the moment?
Many thanks
topquark
Electricians Arms Member
Mentor
Electrician's Arms
Trainee Access
Depends on the manuf, around £25-30 ATM.
Des 56
Mentor
Electrician's Arms
Gliese 581C
It certainly does :eek:
I know of a outlet near me where they go for as little as £12
I have tried one or two and there have been no issues as yet
The big name makes with the big price tags dont mean quality any more
Amp David
Mentor
Electrician's Arms
Trainee Access
Glossop
Do the same myself. MK CUs cheap as chips at toolstation too. Just make sure you use the main switch from ECD to then its a perfect fit!
mogga
Just me
Kirkintilloch by the canal
last time i had to get a hager RCBO only wholesaler with a 40a in stock where I required it FortWilliam was the three lettered ripoff merchant but still only £25 I recon the guy was having an "off day" lol
R
rocker
Used dozens of Zahlers (the ones from Meteor) and not had a problem yet. And they fix wylex et al.
DurhamSparky
nice to know Rockstar!!
So far got Wylex and MK covered with cheap RCBO'!!!
need to start making a definative list to keep in my pocket for pick n mix DB's
pennywise
Regular EF Member
London
Europa fit hager perfectly
Also you can make the standard 10 way17th hager boards into 16 way units the front cover has some blanks you can just knock out if you need the bigger unit. We just buy lengths of bus bar and a few of the larger neutral and earth terminals
R
rocker
NSB style wylex, which I call normal wylex (the same type as was on the recall, similar in form to newlec and crabtree loadstar). Lately, though, most wylex I get hold of have a busbar connection slightly further towards the front of the breaker, closer to the schneider position but not quite as far forward.
P
Phil
I have had nothing but trouble with the wylex rcbo`s. the plastic keeps snapping on the top when terminating.
R
rocker
I finally had a crack at a BnQ special Nexus board this week and to be fair they are pretty good, may do a bit of a post on it in the products section, but for the purposes of this post, the breakers are closer to the schneider type.... an LG breaker would fly into the Nexus board.
R
rocker
Oh yea and @ phil I fond that problem with most types of RCBO, you get a bit of a split where the plastic joins where you do them up tight!
Dcf
Regular EF Member
Just got done 60 quid for an mem alb32!! New ones don't fit the old boards and the pods r not available anymore oh n the new
memshield 3 rcbos are 57& vat! I think eaton are on crack if they think we are gonna use their stuff at this price.hager for me usually 24.00& vat
P
Phil
you would have thought they would strengthen them for us that are heavy handed :D the last one i touched just split and i hardly even touched it. i reckon i will be getting them from metor from now on
DurhamSparky
last bathch of MK ones did that also!! not happy!! i just poked them back in and turned a blind eye!
Status
Permanent unswitched live colour?
  • Brown
    Votes: 60 66.7%
  • Black
    Votes: 30 33.3%
Electrician Talk
