Discuss RCCB as main switch? in the Electrical Forum area at ElectriciansForums.net
N
Noob2013
Hi all,
I have been to a property where the tails come out of the meter and into an RCCB which then feeds the main switch of the consumer unit. All circuits are protected by MCBs.
If I'm adding a new circuit, is it best put in an RCBO instead of an MCB?
There should not be a 'front end' RCD installed at all. Circuits should be separated so that if a fault occurs the whole installation does not trip.
Yes lets rip it all out and start from a fresh.. and then also get rid of the 100mA time delay RCD's from them old installs lol
Hi all,
Hi Noob,
A new circuit would need notifying under Part P of the building regs. As your profile shows that you're an apprentice you could maybe undertake this job with one of the electricians that you work with.
Also, if you don't already have it, get yourself access to the trainees forum.
cobblers. this was most likely to regs. when installed. there's no requirement to bring it up to current regs. although any work done on the installation must comply to 17th.
"most likely"
good enough for you. Not good enough for me.
As soon as he disconnects the tails to the existing he must be happy with the current installation before he reconnects it.
Just my opinion.
"most likely"
Just my opinion.
as long as it's safe for continued use. the fact that it was installed to a previous version of the regs. is no reason to condemn it. that's like condemning a 1990's car because it doesn't have abs or airbags.
Hi Noob,
Can't we have an "Apprentice" badges Mods?
Not condem but advise and make sure it is on the cert if the home owner does not want it.
New posts
Reply to RCCB as main switch? in the Electrical Forum area at ElectriciansForums.net
