Discuss RCD Problem - HELP NEEDED! in the UK Electrical Forum area at ElectriciansForums.net
A
arry01
First off I dont claim to be great with electrics!
I have installed a new consumer unit today, from the meter it has some 16mm T&E tails at considerable length - maybe 10 meters where I have put a KMF switch with an 80amp fuse.
The board is a 2 way split, when i open the main RCD switch at 100amp to the CU that sits open, when I open the 2 x 63amp RCD's one snaps back in a fault condition whilst under no load at all. The other sits comfortable operating some lights.
Assumed it must be a faulty RCD i thought i would swap them, same problem.
I cant work out what is going on here and would appreciate some help, has anyone seen this before please?
Many thanks in advance.
Harry
Are you working in your own home or at a customer. If you're working for a customer you're required to be 'competent' and saying you're not great with electrics is making me wonder.:shocked:
Did you test the circuits for insulation faults or crossed/borrowed neutrals before you installed the CU? If so what were the results?
Harry
:juggle:
I'm saying nowt for fear of a ban. where's glennsparks when you want him?
Harry
I believe its called not being competent!
Maybe best to call a local electrician to take a look. :)
Okay the OP hasn't returned with answers to questions so I'm closing this. Arry01, you're welcome to PM me and state your case with more info if you want the thread reopening.
After receiving a PM from the OP explaining a few more things, I'll be nice......
You have what is called a "borrowed/shared neutral". First point of call is to conduct a continuity test in between the neutral bars. Close attention should be given to the lighting circuits and the possibility of crossed over legs of RFC's.
With the Quals you have + your test equipment. You should figure this out in no time.
Thread re-opened
Reply to RCD Problem - HELP NEEDED! in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
Hoping someone maybe able to help. We have a Horstmann electronic 7 that's connected to the water heater element(everything been great for years)...
