Discuss rcd problem in the UK Electrical Forum area at ElectriciansForums.net
stodsy
hi just left a job where a spark has had the money for a rewire and not supplied a cert and there is a fault when the sockets in the house have any thing plugged in it trips the rcd on the other side of the board I have tried ir on the kitchen ring and its good back there inda morning but any info would be good
Re the RCD trip - suggest they get a competent spark?
Re the cert AND notification - they need to contact the spark - by writing. I'm assuming they know where he lives, and if hes a scheme member they should contact the scheme.
Start at basics. Make sure there isnt a neutral from one side of the board connected to the other sides neutral bar. It happens.
Failing that completely remove the circuit from the db and check for N-E fault.
Does it trip only when load is applied to that circuit? No others?
That neutral bar is for any rcbo's you might want to use. Ie for fridge/freezers etc.
Rogue neutrals are a real pain these days, and changing a db used to be oh so easy....... Not any more!
Reply to rcd problem in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Been a while since I have been on here. I have been on an apprenticeship the last 3 years training in the BMS world. Taking that into...
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
Cant get my head round this :( I understand N-E faults cause RCD's to trip, but I cant understand why on these 2 occasions, googled allover but...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
